parallel port error 3
I find that my Labview program suffers from Parallel Port Error 3 - an error whose meaning I'm clueless about.  I am communicating with an ADE7753 chip, and communication between Labview and the ADE has worked successfully before.  Now it's error 3 and gobbledy-gook on the data read.  Anyone ever encounter this error?
(2,682 Views)
I have a couple questions/requests to clarify the problem:
0. Is this on the same computer which it formerly worked; what OS are you using (and verison of LabVIEW)?  If you are using Windows 2000, please see the following: (as well as the related links, including a tutorial on accessing the parallel port using LabVIEW)
[link removed; article no longer available]
1. please attach a screenshot of the error
2. can you successfully use the shipping example named Parallel Port Additional Data Register Inputs.vi?
In the event you haven't already, check out the link and the shipping example, and if you're still having trouble please post the error screeshot.  Also, if you can recreate this with a very simple example, you can post that as well!
Best Regards, and looking forward to your repost!
JLS
Best,
JLS
Sixclear
(2,670 Views)
