parallel port - once more
Hello everybody
I have still problems with LPT ports communication.
I want to access data line 1,2,3. I have downloaded and installed
accesshw and tried "port out" and many others. All I got is error
nr. 37. I learned that it means that Labview can not see the
device, but how I should make it visible.
I even add a line in labview ini file like:
serialDevices="COM1;COM2;LPT1"
Did not help.
I have Windows NT 4.0 workstation. LV 6.0.
Best regards
PP
(3,011 Views)
I found the following link useful
http://www.advmeas.com/goodies/parallelport.html
Good luck
Keith
(3,011 Views)
Something I forgot to mention
The port number for the Seral Port Write.vi depends on the position of LPT1 in your serialDevices list ie. COM1 is item 0, COM2 is 1 and LPT1 is 2. So you'll need to use 2
Hope I haven't confused you!
Regards
Keith Fuller
(3,011 Views)
Thank you, it works now. I have found parallel_NT.llb
Best regards
PP
(3,011 Views)
