parallel port
Anyone knows if exist some Vi that explain how make a digital handshaking
with a device connected by parallel port.
Thank you in advance, Andrea.
(2,898 Views)
Hello Andrea,
You can use the In Port and Out Port VIs (in the Advanced >> Port I/O palette) to read from specific register address. These VIs will only work for Win 95/98 computers.
I recommend that you use the information from this site: http://www.fapo.com/eppmode.htm to assist you with adress designations, and calling conventions.
For additional VIs that access the parallel port, please go to the National Instruments Example Program database: http://www.ni.com/support/epd/, and use the search words: +labview +"parallel port".
(2,898 Views)
