parallel process in labview
I have an image that i split in 2; left and right, and they both go through the same process of plotting a line. In order to see the process for both images, I have to do parallel processing to see the lines for both left and right graphs.
I put a while loop on both left an right image processes, but i still have the same output. Can someone help me?
(4,522 Views)
Your picture doesn't help us help you, i'm afraid, can you post the code?
There's generally no need for parallel processing to show 2 graphs, it's usually quite sufficient to plot them sequentially.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,512 Views)
(4,506 Views)
It doesn't look like a lot of processing, so like suggested above, just put both graphs / all code in one loop. See what happens.
Richard
(4,494 Views)
As a rule of thumb, copy-paste code is not usually a good thing. Like was stated above, there is not much processing, no need to do it in parallel. I would build the two arrays you have into a 2-d array. Then use an auto indexing for loop with all the identical processing in it. From there you can build your x input and y input arrays for your graph and feed them to your xy graphs. Hopefully this is clear. If you post your code in version 8.5 I can draw it up for you.
(4,486 Views)
(4,469 Views)
