parallell while loop slow
Hey Everyone!
I have a problem with my while loop that makes my agilent digital multimeters read
values slow and I wonder how a easy fix for that would be. I hope anyone can explain a easy thing to change that would make the values read faster. I upload my vi file here for my setup and preciate anyones help.  thanks
(2,006 Views)
Can you clarify what's "parallel" about your while loop?
Every milliseond you are trying to create six new files using express VIs. Does not sound reasonable.
(1,991 Views)
I only see one loop.
Bill
CLD
(Mid-Level minion.)
(1,987 Views)
Do you really try to read values from 4 Agilent multimeters in parallel?
Due to how that driver is written, the request will not be executed in parallel but one after the other as all VIs are not reentrant.
Regards, Jens
Kudos are welcome...
(1,979 Views)
Yes I am trying to read from 4 multimeters. I have used a while loop to take values for each single measurement value into a table. Is there a possible way to fix that in a way for it to be faster?, because the multimeters does show the values fast but not when I am trying to connect to labview.
(1,935 Views)
