parametric control knob
I want to make control knob with parametric limits and parametric increment/decrement step.
I have Power Supply with output range 0...30V.
Typical knob adjusts output the voltage from minimum (0 V) to maximum (30 V).
I want to create special knob, which can be programmed in such way, that its lowest and highest values can be programmed.
E.g. I want to use full range on the knob to adjust voltage in range 4 V to 6 V.
In addition, I want to have 0.1 V or 0.25 V or any other step.
Marek
(1,017 Views)
Those properties can be set programmatically using property node.
https://tmesystems.net/
(984 Views)
