parent kill his child with VI-server
I use a VI-server (parent vi) to start another VI (child) with a closed front panel. When the parent stops running he killed his child. How can I avoid this? There is no problem when the front panel of the child stays open.
(2,628 Views)
Ah yes! The 'ole no front panel, no running VI situation. Here's the secret -> Make sure the "child" opens a VI Server reference to himself (or herself if its a girl). As long as LabVIEW sees an open reference it will let the child live on. I believe the exception is in a build executable, you must have one front panel open (even if its hidden).
Dan
www.primetest.com
(2,628 Views)
