parse out global channels
I have cDAQ 9172. The users will enter different global channels and I want to parse out the digital channels and have them in a seperate array. The other channels should be in the same order as the user selects. I am reading in global channels that will always be in the same format but never in the same order. Example: 9401-DI-1:2 .... and 9205-VI-1:3 and 9237-PI-1:2 would end up in two tasks. The Analog In tasks will be 9205-VI-1:3, 9237-PI-1:2 and I would then have a different task for the Digital Input 9401-DI-1:2. The user should be able to enter tasks in any order.
(3,040 Views)
Accepted by topic author bassinbc
Well I solved this myself. Didn't see the Match Regular Expression Function. That allows the use of the or function and makes things a whole lot earier.
(3,031 Views)
