parsing carriage return characters
Hello
I am writing a program to parse fields in messages. The messages look like this:
Field 1.1|Field 1.2|Field 1.3| ... |Field 1.n<carriage return character>
Field 2.1|Field 2.2|Field 2.3| ... |Field 2.n<carriage return character>
To parse this, i used the "Scan string for Tokens" VI, using "|" and "\r" as delimiters, storing all the field in an array. The implementation can be seen in the attachment
The pipe character works fine, but the carriage return does not.
I get this at the end of each line:
"Field 1.n
Field 2.1"
The program is not using the carriage return character as a delimiter. I am using LabView 7.0 Express.
Can somebody tell me what is wrong?
Thanks in advance
(3,058 Views)
Make sure that the elements in the Delimiters array have the "\" Codes Display option enabled (to set, right click on any element), then re-enter the \r constant.
It works for me.
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,046 Views)
I am using | and \r as delimiters. It has the backslash character. I don't understand why this does not work.
(3,044 Views)
I already got it.
I didn't know i had to enable an option to make the program interpret \r as a carriage return.
Thanks, Paolo
(3,039 Views)
