partial clean up needs wires (BUG LabVIEW 2009)
The new partial clean up feature of LabVIEW has a little glitch, it needs a wire to be selected to actually perform a clean up.
For isntance the following VI:
C:\Documents and Settings\Meetlaptop gebruiker\Local Settings\Temp\Example_VI_BD.png
Where I have selected the top and bottom primitives, when I hit the LabVIEW clean up button, the selection will not be cleaned up.
Ton
My LabVIEW Ideas
Message 1 of 11
(4,709 Views)
Looks pretty clean to me. What do you expect it to do? 😉
Message 2 of 11
(4,688 Views)
Ton,
It looks like you are using the diagram clean-up like I use ctrl-s. I hold by my opinion that you can't save too often but I think you have found a case were the diagram is too clean. Smiley Wink
Ben
Message 3 of 11
(4,681 Views)
It's my fault. We were testing this feature for the CCT and I was running it on a VI which only had a few unconnected nodes. The cleanup worked when I pressed the button but didn't work when I called the method and I guess this is the description Ton ultimately came up with.
___________________
Try to take over the world!
Message 4 of 11
(4,659 Views)
I expect LabVIEW to align the code.
I don't have LabVIEW currently active, but if you add a wire between two of the nodes but not select the wire the clean up will be a no-op as well.
Only with a wire selection it will actually clean up.
TST:
I have seen no difference between the toolbar button and the 'cleanup' invoke node.
Ton
My LabVIEW Ideas
Message 5 of 11
(4,611 Views)
Yes, I certainly agree with you. 🙂
(It's just not a big show stopper)
Message 6 of 11
(4,592 Views)
You're expecting quite some intelligence here. How is LabVIEW supposed to know how you want the items to be wired? Are they going to be used in series or parallel execution? If it would know we could as well expect an auto-wiring button instead of just a cleanup button (would actually be nice Smiley Happy )
Just my 2c.
Daniel
Message 7 of 11
(4,577 Views)
I thought the partial clean up was only supposed to clean up what you have selected.  Therefor if you don't select a wire, why should it clean it up?
Message 8 of 11
(4,553 Views)
We're not expecting any additional intelligence, nor do we want LV to clean a wire which wasn't selected.
The point of the bug was that the cleanup for these objects works if you don't select anything, but doesn't work if you select just these objects. As the others mentioned, this is far from a critical bug. Most people are unlikely to clean up such code anyway. I needed to test something unrelated, so I wrote a quick VI with no wires.
___________________
Message 9 of 11
(4,540 Views)
How do we define "Clean" if there are no wires giving context to the objects? It strikes me as "Clean up that sentance!" given only a collection of nouns. What is clean in that sense, arranging them alphabetically? That would be clean but would not help the understanding of the sentance.
Just my 2 cents,
Ben
Message 10 of 11
(4,496 Views)
