partial least squares
Hi Guys,
I am trying to learn to do some chemometrics analysis to bo done using LV and all my search for some starting point did not give me any clue where to start. I saw many forum discussing about this and not much is done on this. Where as I find Mathlab have done a good job on this with many using it for PCA and MAD analysis. Can any one help?
Thanks in advance
Message 11 of 13
(1,324 Views)
Hi Dinitis,
LabVIEW does provide a lot of mathematical analysis functions, which can be used in a lot of different fields, Chemometrics being one of them. Truthfully, Chemetrics specifically is not a major field in which LabVIEW is used, therefore there really is not a lot of information on the National Instruments Website. I would suggest searching on google, as I believe you will be able to find more information on this.
As far as the few links on our website I would recommed you look at these:
http://forums.ni.com/ni/board/message?board.id=170&message.id=237118&requireLogin=False
Eli S.
Message 12 of 13
(1,299 Views)
Partial least squares regression is an addition of the multiple linear regression models. In its simple form, a linear model details out the linear relationship between a dependent (response) variable Y, and a set of predictor variables, the X's, so that
Y = a0 + a1X1 + a2X2 + ... + apXp
Informatics Outsourcing is the Market Research-Partial Least Square Services Company. They are handling customers Worldwide.
To know more about the service… http://www.informaticsoutsourcing.com/quantitative-market/partial-least-square.htm
Message 13 of 13
(1,084 Views)
