particle analyser object extract
I am new to labview. And might not know some basics for the questions I have. I have two questions.
1. In the vision assistant, the particle analyser separates objects, and show them as results 1, 2, 3..(As shown in the picture). However, the output is given only as total number of particles/objects.
I want to extract these objects in real time, so that i can do further image processing on them. So basically, i want the output as: Object 1, object 2..(till the number it will detect from the camera) and in the exact shape. So that i can perform task on them individually. Or you can say that I want to extract each object from image.
2. This must be fairly basic. I want to connect a projector to labview. I have used the vi shown in the picture for it, but its not connecting or projecting from labview. Is the vi wrong? What’s the alternative?
Appreciate all your help,
Thank you.
Message 1 of 1
(2,667 Views)
