pass bitmap
In a VB .NET environment, can I pass bitmaps into a dll built using LabVIEW 7.0?
I can use the following to pass in two arrays. But what kind connectors should I implement in the LabVIEW side? Use Image or 2-D array? Thanks.
' VB .NET code
IMAQ.AcquireImage()
Dim objImage As Object = IMAQ.Images.Item(1).ImageToArray
(2,730 Views)
John,
Passing a 2D array from VB to LabVIEW should be possible.  Take a look at the discussion forum thread below, it might give you some insight...
Labview dlls in vb
Good Luck,
Lorne Hengst
Application Engineer
(2,704 Views)
