pass data to a second loops
hi to all members
i do face a problem to pass data from the first loop to the second loop
the second loop do contain an event structure
but no luck
(3,640 Views)
What problem do you face?
You say you have a problem but have not provided details.  I can guess, but that I might be guessing the wrong thing.
What is your VI doing wrong?
Do you really want that first loop running at the speed of light?  It's going to do the same operation over and over again as fast as the CPU will allow.  That should probably be it's own event case in the second loop.
(3,623 Views)
thank you for replay
no of course i need to  put a delay sorry for that
my main problem is to pass a Boolean data from the first loop to the second
so i can use it to trigger the select pallet
can you please download the vi
(3,616 Views)
(3,571 Views)
Accepted by topic author Mood_B
Hi mood,
I would suggest to learn the basics of event structures!
They
- don't react on writing values to an indicator (by wire), neither for "logical AND 3" nor "local variable indicator"!
- block until an event occurs, so putting a wait function in parallel is mostly senseless
- react on UI interactions, values written to "value (signalling)" property nodes, or user-defined events
You should:
- learn LabVIEW basics
- put all code into one just loop
- get rid of local variables: use notifiers, queues, channel wires for data exchange
- use the AutoCleanup from time to time…
(3,567 Views)
Value signaling property node.
worked fine
thanx
(3,540 Views)
