pass list box to a sub vi
I have a main vi that has a list-box in it.
i want to pass this list-box as rerference to a sub-vi and let the sub-vi change its properties (like item Names) and to see the changes in the
main vi.
thanks in advance
(2,873 Views)
Hi
You already have the solution in your question. You want to pass a reference of the list-box to a sub-vi to change the properties - so just pass it to the sub-vi.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,868 Views)
Right click on the terminal of the listbox and from the context menu select create->reference. Then right click on the reference and click create->control. Copy the reference control onto the front panel of your subvi and after you have saved the subvi, drop it on the block diagram and wire the reference to it.
(2,868 Views)
