pass reference to 2D array with multiple rows -> subvi - sees only 1 row of many rows
What am I doing wrong?
Message 1 of 10
(3,793 Views)
Hi MrNatural,
can you show a picture or your vi?
Mike
Message Edited by MikeS81 on 02-11-2009 08:08 PM
Message 2 of 10
(3,792 Views)
If you are doing any array indexing, are you sure you didnt accidentally select 'first row' instead of 'all rows' or something similar?
Or does the array go into a 'For' loop at any point? Because then it will autoindex as well.
Could you please post an image or a VI so I can see whats going on.
Cory K
Message 3 of 10
(3,773 Views)
The attached vi and subvi show the problem.  The array is 5 rows by 3 columns yet the reference's number of rows property is one/uno/un/ichi/ein/1
Message 4 of 10
(3,760 Views)
This time I hope to upload the zip file I intended to upload last time.
Message 5 of 10
(3,757 Views)
The "Number of Rows" refers to the number of visible rows. This is exactly what it says for the documentation on that property (did you read it?). The Array Size property will tell you how many rows the array actually contains.
Message 6 of 10
(3,754 Views)
I kind of guessed that but:
  Can't get array size of the reference and none of the properties seems to be useful for that purpose
Message 7 of 10
(3,751 Views)
Accepted by topic author MrNatural
Sure there is. The Value property. Feed that into Array Size. The output of Array Size will be an array - one element for each dimension of your array.
Message 8 of 10
(3,745 Views)
Thank you.  It works but, let me say, the solution sure is a typically fussy way to get a simple answer.
Message 9 of 10
(3,738 Views)
True, it would be convenient in this case (and possibly others) to have Array Size as a property. I would suggest submitting this the Product Suggestion Center.
Message 10 of 10
(3,726 Views)
