passing a pointer to an array causes my VI to crash
Hi guys,
I am in phase of learning LV. I am trying to call the following method in a DLL written in C++.
int PimReturnStillFrame(HANDLE hImager, LPVOID pBuffer, float exposureTime);
the second param is a pointer to the array receiving the raw data of the frame from a Camera.
I tried using a constant array, it didn't work for me.
Then I tried uaing the "Initialise Array" method in LV; however my vi crashes each time I run it. I thoght that the size of the array is small comparing to the data, so I tried increasing the size but it didn't work as well
how can I pass an array pointer to this method in which the raw data can be stored?
Any help would be appretiated
Many thanks
(if u want I can post the vi
(2,659 Views)
The memory layout of a LabVIEW array is different than the standard C-style array. Read "Using External Code in LabVIEW" (search in help) and look through some of the examples.
(2,659 Views)
Hi again,
I've tried reading that bit of the help, but it didn't solve my problem. The thing that I couldn't get is that in the method declaration the pBuffer parameter is of type LPVOID which is a PU8 (pointer to unsigned 8 bit integer). How can I specify this value? I have tried using array and constants (U8 values) it didn't work ....
can you plz help me
(2,659 Views)
If you are pointing to a single unsigned byte (i.e. not an array), pass it by "Pointer To Value" with the Data Type as "Unsigned 8-bit Integer."
(2,659 Views)
