passing error wire - connected to an undirected tunnel
How can I pass error cluster wire between stacked sequences ??
 For example in the state machine -  the error cluster wires should pass data from previous stacked sequence CASE 0 to CASE 1.
How can I do that ?
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
Message 1 of 14
(6,862 Views)
Use an actual state machine. A stacked sequence structure has no place in LabVIEW programs anymore. Learn how shift registers work.
Message 2 of 14
(6,856 Views)
I have searched many times on this forum.
How can one do the following in terms of state machine :
  1. Have a FOR loop that has N cases
  2. For each iteration "I" the cases 1-N repeat.
One way is to convert those 1-N cases to another state machine and reuse it under the main state machine (for example the one I showed).
How else could one do it., Please explain this. As this is most common kind of coding I will have to face through out my development and I dont want to complicate it by having nested state machines.
Even a simple sketch will do it.
Thank you.
Abhilash S Nair
LabView Gear:
Message 3 of 14
(6,843 Views)
Consider creating a subVI of each frame and wire them sequentially. This might be much easier to read than a stacked sequence.
If you really want to keep the stacked sequence you could pass errors via Sequence Locals between frames but I would not recommend this.
Message 4 of 14
(6,842 Views)
So what you mean to tell is create sub VI  for each frame of the CASE structer and connect them sequentially inside the FOR LOOP .
Am I understanding what you said in the correct way.
What if I want to give something very simple like WAIT(ms) between the first and second SUB VI. How can I connect them through with out a flat sequence ?
Abhilash S Nair
LabView Gear:
Message 5 of 14
(6,833 Views)
That's what I thought. It seems a little bit overkill to me to replace a stacked sequence with just 2 frames by a state machine, I think subVIs are better suited here.
Regarding your second question: You need a flat sequence here. Place it on the error wire between the subVIs and put the Wait primitive into it.
Message 6 of 14
(6,827 Views)
How about the question I asked about introducing a wait(ms) in between the two sub VI. How could I do that then ...
Abhilash S Nair
LabView Gear:
Message 7 of 14
(6,825 Views)
Sorry, I read your second question too late and decided to edit my original post. You find the answer there 🙂
Message 8 of 14
(6,820 Views)
How about like this ??
Abhilash S Nair
LabView Gear:
Message 9 of 14
(6,817 Views)
Looks OK to me. If you need the Wait in the error case frequently in your project this would be a good candidate for a subVI, too.
Message 10 of 14
(6,796 Views)
