passing images in clusters takes a lot of time
hello
When I insert an image in a cluster by using the node "bundle by name", it takes approximately 15 seconds if the image is a 80X80' QR/code (1 pixel per bit)
thus, the more there is images to insert, the more it takes time (image below)Sans titre.png
I m using this way because I display those qr codes within a strict type def.
do you have any suggestion to pass images faster?
thanks in advance
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(3,000 Views)
Hi Pierre,
please provide an example VI demonstrating that behaviour.
We cannot comment anything from that small image you embedded in your post…
(2,980 Views)
I agree with GerdW -- we need to see, and be able to carefully examine, the entire VI.  Attach the VI itself.  Among other things, we need to be able to figure out (or simulate!) details about the QR image, including its size in memory (as I read your post, you talk about an 80 x 80' QR code, which I read as "eighty by eighty feet QR code", and thought "Wow, that must be a lot of pixels" ...
Bob Schor
(2,954 Views)
