passing png to excel
I'm trying to figure out how to pass a png file to display in excel. I do have the report generation tool kit. Any examples would be greatly appreciated.
thanks
(3,233 Views)
Are you using the IMAQ vis, the picture vis, or are you just creating your own PNG (ie, just the pixel values?)?
While I haven't personally tried this, (I will once I get your response) you could probably utilize the ActiveX controls for excel to literally paste the PNG into a spreadsheet.
Chris Van Horn
(3,225 Views)
Accepted by topic author TCjr
TCjr,
You should be able to use the Append Image to Report.vi to do this.
(3,221 Views)
I read his post three times, and each time, my brain said "I don't have the report generation toolkit."
This VI is exactly what you want if you have the toolkit.
Chris Van Horn
(3,219 Views)
