passing value out of a while loop
Hi guys!
I'm new to LabView and I've encountered some problems passing a value, R, out of a while loop when using a particular VI as a Sub-VI. I've attached the library file for my program.
The VI that encounters this problem is called TEST.VI, which uses the LockInDemoSimple.VI as a sub-VI. The indicator value in TEST.VI does not update itself at because the value R has problems being passed out of the while loop in LockInDemoSimple.VI. Can anyone suggest a solution to this?
Thanks a millionz.
(3,973 Views)
    While loop doesn't pass value out of it until it stops. so as long as yor LockInDemoSimple.VI running you will not be able to get R on Test.vi.So make required changes sothat the loop will stop and throw value out of it. Secondly you can use globel appropriatly to achieve it.
Let me know if you are again in trouble.
(3,961 Views)
Hi once more,
I tried using global cos' I do not know how to stop the while loop by itself, throw out the value, and start the loop again. It works fine, but this program itself takes up 100% of my CPU capabilities and 'lags' my other program which is required to run simultaneously with this program.
Do you have any idea how to resolve the problem besides switching to a better computer?
Thanks.
(3,916 Views)
Hi, you were observing that 100% CPU loading because your program's Sub vi execution was not properly controlled
I have modified ur Test program to do following
Control the execution of the loop in Demo VI
Pass the R value from the  loop in Demo VI through a global variable to display on the test VI
This should not load your CPU's resources
Regards
Dev
(3,911 Views)
Hello group,
I am a new member of the group.
I want to know whether it is possible to configure LabVIEW with Modbus or Profibus.
If yes the can anubody tell me how can we do that in detail.
Srinivas
(3,908 Views)
for the modified program, I can't seem to stop after I pressed start....
(3,870 Views)
Hi Srinivas,
You should post your question in a new thread, since this one is for "while loop" only.
Check out this link, which may help you.
http://forums.ni.com/ni/board/message?board.id=170&message.id=156492&query.id=73571#M156492
(3,858 Views)
