patent of .VI
how do one gets patent for a new application VI developed by himself?
Smiley Indifferent
Message Edited by sukhiray on 07-17-2008 08:25 AM
Message 1 of 16
(4,197 Views)
You wouldn't necessarily be able to get a patent (the code would have to meet some requirements), but here are some details about software patents. The rest depends on the process in your specific country.
___________________
Try to take over the world!
Message 2 of 16
(4,174 Views)
By the way, do you really think you need a patent?
It's probably one of those things that if you have to ask how much they cost then you can't afford them, meaning that if you needed to file a patent, you would probably know how to do it already.
In any case, I doubt the concepts embedded in a single VI would be patentable. You would probably need to patent an algorithm or a combination of concepts and code.
___________________
Message 3 of 16
(4,169 Views)
if getting patent is not possible (or very difficult), in that case is it possible to get copy right of the same?
Message 5 of 16
(4,111 Views)
Sure, but the laws depend on the country. For instance, in the US: http://www.copyright.gov/help/faq/
Message 6 of 16
(4,105 Views)
thank u. but i m from India.Smiley Sad
Message 7 of 16
(4,099 Views)
Then check Indan law.
Remember:
Message 8 of 16
(4,094 Views)
thank u again
Message 9 of 16
(4,088 Views)
Took me about 30 seconds to find http://www.copyright.gov.in/.
If the intent is to prevent someone from using a program you wrote without your permission, you might want to consider some other sort of protection. There are software (i.e. linking a license to a disk driver id or a MAC) and hardware solutions (i.e. dongles).
Message 10 of 16
(4,080 Views)
