path control limit extention type
How do I use a path control and limit the extention? I do not want to have *.* All files available.
Message 1 of 8
(5,892 Views)
Create a property node and select "Browse Dialog Options -> Match Pattern" to limit the type of extension you want.
Message 2 of 8
(5,891 Views)
If you don't need to change the extensions dynamically, you can just right-click the control and choose �Browse Options��. Type the extension in the �Match Pattern� field (e.g. �*.*� in your case, and maybe �*.vi� in other cases). Please see the attached image for an example.
I hope this answered your question.
Philip C.
www.ni.com/ask
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 3 of 8
(5,891 Views)
festo wrote in message news:<5065000000080000008B020100-1079395200000@exchange.ni.com>...
Right click the control and select 'Browse options...'
Message 4 of 8
(5,891 Views)
I forgot how to limit the type to REMOVE "*.* All Files"
Message 5 of 8
(5,817 Views)
Hi festo,
I'm not sure that I understand your question. Do you want to specify certain file types to browse for? In that case, add the file type you want to be able to browse for to the 'Match Pattern':
Let me know if this is not what you want.
Message Edited by Philip C. on 05-26-2005 09:53 PM
Thinkbot Solutions
Message 6 of 8
(5,807 Views)
My problem does not have to do with specifying certain file types. The issue is when the control is activated, I do not want an end user to be able to select "All Files (*.*)".
Message 7 of 8
(5,796 Views)
Hi festo,
As far as I know, there's no way of removing the "All Files (*.*)" choice from the "Files of type:" menu. If you absolutely need this choice to be removed, you can create some code that calls the Windows DLL that creates the "file open" dialog, by clicking a button on the front panel of the VI.
Let me know what you choose.
Thinkbot Solutions
Message 8 of 8
(5,780 Views)
