path file control indicating the installation file directory
I'm making a package on labview 6.1.
Once this package is installed on a pc the software will use some txt files.
On my code I specified the directory of these txt file but if the user want to change the install directory given by default, the txt file will be no more accessible.
Is there a possibilty to put a control in the labview code that allow to take the real install directory of the exe and then indicate the name of the txt file.
Thanks for your help
Regards
Popo
(3,331 Views)
use the function
current vi path from the FIleI/O pallete-----File constants
get the main vi's path ( (using this function), and then set all other file paths relative to the main vi's path.
use function build path
(3,323 Views)
Dr. Imad a écrit:
use the function
Many thanks
Popo
(3,318 Views)
Dr. Imad, et al.,
I just wanted to expand on your post to clarify the intermediate steps that must be taken for this to work correctly.
The output from the "Current VI's Path" vi needs to be wired to a "Strip Path" vi to remove the current vi's name from the path.  The "stripped path" terminal is then wired to the "base path" terminal of a "Build Path" vi.
Thank you for the great information; it helped me over a hurdle I had been struggling with.
DaBayer
(3,238 Views)
