pathdialog displays only filenames?
i try to open a file over the pathdialog, but when i have a long path, the filename was not visible because the display are to short.
Is there any possibility to display only the filename, without the path.
Thanks Florian
(2,722 Views)
use the strip path Vi to get the file name
regards timo
(2,716 Views)
it´s a nice idea, but for this i need a  second indicator.
I try to find a solution without a additional indicator
Florian
(2,711 Views)
Hi Flori89,
what about using the file dialog vi?
a dialog appears and you can select the file
regards timo
(2,703 Views)
Could you explain what you mean by "pathdialog"?
If it is just a path control, you can also resize it vertically and the displayed path will then wrap onto several lines if needed.
(2,699 Views)
