pc-tio-10 qbasic/pascal/c dos examples program
I am searching simple example program (in qbasic or c or pascal) for pc-
tio-10 board. Where can I find them?
Thanks, Angelo.
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,445 Views)
Angelo,
Your best bet is probably to install version 4.6.1 of the NI-DAQ driver for
DOS; there were examples there for "Microsoft C, Borland C++, QuickBASIC
4.0/4.5, Microsoft BASIC 7.0 and 7.1, Visual Basic 1.0 (!), and Pascal
7.0." I did it for kicks and found an example called "freqxmpl.bas" that
demonstrated how to do frequency and duty cycle measurement with the TIO-10.
You can find NI-DAQ 4.6.1 here:
http://digital.ni.com/softlib.nsf/websearch/a049d6943045122a862566db005f281a
Of course, you'll get better support and more flexibility if you use a more
up-to-date development environment and OS, but this should get you going.
John Lum
angelo4686@my-deja.com wrote:
> Hi,
al) for pc-
> Thanks, Angelo.
> Before you buy.
(3,445 Views)
