pci-6602 VI can not work on win7
Hi I have a vi output fix frequence through pci6602, it is can be worked on win xp and labview 8.5, but after upgrade to win7/labview 2013/Daqmax 9.7, these SubVis of 6602 are changed, so this Vi can not be worked. is there anyone can kindly help me? thanks Best Regards Rex
(3,122 Views)
Hi Rex,
when you speak of "these subVIs" you should attach them - or describe in clear words, what has changed due to changing the used PC…
Did you use TraditionalDAQ on your old PC, which is (maybe) missed on your new one?
Does MAX recognize your PCI6602 card? Can you test the card in MAX?
(3,117 Views)
Hi GerdW, thank you for your reply first, you can see they in attached zip file, that are pictures. what is different between TraditionalDAQ and DAQmx? I don't install TraditionalDAQ on my new PC.
(3,111 Views)
Hi Rex,
which files?
TradDAQ and DAQmx are completely different drivers for your hardware!
It is recommended to use (the newer/modern) DAQmx functions. That also means you need to rewrite your VIs when you used TradDAQ until now. If you don't want that (or cannot do this) you need to install TradDAQ too. It may lead to other troubles as is indicated in those compatibility charts
(3,108 Views)
Hi
(3,103 Views)
Accepted by topic author Rex123
Hi Rex,
DAQmx comes with a lot of example VIs in the LabVIEW example finder. There are examples for Frequency output too…
Your old version used DAQmx functions as can be seen quite clearly in your picture.
The new version uses some "DAQ Pilot" functions - I never heard of such and I don't know where you got them from…
(Remark: I cannot open your new version VI due to it's LabVIEW version.)
(3,100 Views)
