pciture control: programatically disable certain values
Our software has user levels where control references inside a cluster are in certain levels. Noobs cant use certain features.
Now I have have picture controls at several locations and I'd like to programatically disable certain values. Can I do this?
Let's say I want the user to be unable to select the third value of a 5 value picture control.
Thanks!!
(3,044 Views)
Thanks!!
So, if Newvalue = 3 and Oldvalue = 2, then value = 4
if NewValue = 3 and OldValue = 4, then value = 2
21367i9105BBD769F3CFD7
(3,039 Views)
Yeah that does it... but I was looking for more elegant solution. lets say I have a reference of this control then I'd like to use its reference to control what values are available from another spot -when logging in to the program-
If this is not possible Ill use your solution, but then I need to have different code for other user levels
(3,031 Views)
21389i231307937F683753
Better?
(3,026 Views)
