pcm frame
I need to construct a PCM frame from inputs with different sampling rates such as video and  data. Further, certain analog data  has to be first digitised and then included in the frame. Is there any method of constructing the PCM frame? Is it then possible to use this frame as a stream of bits and further compress it to minimise the bandwidth consumed so that it can be sent on a communication channel?
Message 1 of 8
(5,108 Views)
Hi adiremo,
are you talking about this?
The answer is YES...
But you have to define all those steps and fill the gaps with all needed information!
Message 2 of 8
(5,106 Views)
Thanks a lot It is indeed related to what u have mentioned but can it be implemented in labview in this manner
Message 3 of 8
(5,103 Views)
Hi adiremo,
yes, it can be implemented...
Message 4 of 8
(5,101 Views)
thats good news !!!!
why don't u get me started, it will save me a gr8 deal of effort.:Smiley Happy
Message 5 of 8
(5,095 Views)
Hi adiremo,
"why don't you get me started?"
Because:
- I have a work of my own
- this is a forum of enthusiasts, we don't work for others
- we are here for answering to specific problems and you don't say where you have problems
- you did not provide any useful information (about hardware etc.)
GettingStarted: here
Message 6 of 8
(5,093 Views)
thanks anyway
Message 7 of 8
(5,083 Views)
As a continuation of my earlier question, is this equipment enough for me to construct a PCM frame or is there anything else required. Are there any  better alternatives like PCI 7831 R. I have the FPGA module installed in my Labview software
- NI PXI-1033 Chasis Integrated MXI Express 5 Peripheral Slots
- NI PXI-7831 R
Thanks in advance
Message 8 of 8
(5,045 Views)
