pda daqmx base task information
Hi!
I use LV PDA Module 8., Windows Mobile 5 OS on PDA and CF-6004 acquisition card.
I configure 3 tasks in DAQmx Base Task Configuration Utility, which have different sampling rate and samples per channel property.
Problem is that I can't get this properties programmical, since PDA Module doesn't support Timing Node, so I have no information what sampling rate is set when I select new Task in my application.
andrej
(4,602 Views)
Hi Andrej,
Since DAQmx Base does not offer property nodes or the waveform data type, there is currently not a way to programmatically check which sampling rate was used by the 6004.  If you feel strongly that this feature should be included, I encourage you to create a product suggestion and describe your application in detail.  R&D considers these suggestions very seriously when making decisions about future products.  I hope this helps.
Best Regards,
Jeff Tipps
(4,589 Views)
