pda error downloading
Hello Boris,
I would like you to perform a couple of tests for me.  First change the execution target of your VI to be the Pocket PC Emulator.  Next press Tools->Configure Pocket PC Devices.  When the dialogue window appears, select "Pocket PC 2003 Emulator" and press the "Properties" button.  Press the Test button to ensure that the connection has been made.  Please repeat this process for the Pocket PC 2003 Device and let me know how things turn out.
Thanks, and have a great weekend,
Travis M
Travis M
LabVIEW R&D
Message 11 of 15
(1,481 Views)
Hello
I did what you told me and after a few minutes and some file transfer I  received a message "device connected"
I hope this helps,
regards Boris
Message 12 of 15
(1,480 Views)
Hi Boris,
When you click on "Build for PDA", the processor tries to locate a particular .exe file that gets installed with embedded Visual C++ tools and SDK. In your case is it possible that the embedded Visual Tools and SDK were not installed in the default directory? If so, please uninstall and reinstall eVC tools and SDK in the default directory (C drive , I believe).
Please let me know how it goes.
Ankita
Message 13 of 15
(1,470 Views)
Hello
Just bought a new laptop, so I will try here. i will folow all of your previous advices, and let you know how it goes.
Regards Boris
Message 14 of 15
(1,463 Views)
Hello.
i would like to thank all of you who tried to help. I installed on my laptop, and it works.
Thanks again.
Boris
Message 15 of 15
(1,454 Views)
