pda hide tabs on tab control
Is there anyway to hide tabs on a tab control in Labview PDA (8.0.1), or is this not supported?
Greycat
(3,552 Views)
Sorry, it is not a  supported feature at this time.
Ankita Agarwal, National Instruments
(3,533 Views)
It's not the best method, but you can expand the tab control to bigger than the window so that the tabs are out of the viewable area.  Of course, this only works if it is acceptable for the tab control to fill the entire window (or least to the lower edge where the tabs are located).
(3,530 Views)
And you could try placing something in front of the tabs and controlling its visibility, but my experience with the previous versions leads me to suspect that either the Z ordering would get screwed up or that it would look really bad.
___________________
Try to take over the world!
(3,521 Views)
Thanks for the replys ... I have used buttons over the tabs and that worked fine but some of the other front panel objects appear behind the tab so ... Thanks again ... I will try some different things.
Greycat
(3,516 Views)
