pda pocket pc
I am new to PDA module on labview.I am trying to use emulator for pocket pc 2003. i installed following software on my windows XP system
1.eMbedded Visual C++ 4.0
2.eMbedded Visual C++ Service pack 3
3.Microsoft Pcket PC 2003 sdk
4.Microsoft Active sync.
Now after the activation of pda module i started the pocket pc 2003 emulator and open a new VI and with out adding any thing .Every time i tried to run application it hanged my PC and do nt show me any emulator screen.what should i do any suggesstion.
Nadeem
(3,343 Views)
before to run your VI , you must choice the target: click on "operate" on the front panel and "switch execution target" then select "pocket pc 2003 emulator". after this you can run your VI and the emulator scren will appear.
(3,322 Views)
Dost,
This is a known issue and has been adressed in the following KB:
http://digital.ni.com/public.nsf/websearch/4B5A26F80E59112286256F0B00707723?OpenDocument
Let me know if this doenst solve your problem.
Regards
A Meister
National Intruments Denmark
(3,315 Views)
