pda state is missing vi or c file
Hello!
I have one VI that is working fine in LabVIEW PDA Module 8.0.1.
But when I upgrad this VI in PDA Module 8.20 and try to build it I get this error "state is missing VI or C file"!
I'm not new in LabVIEW PDA Module and I know that it has bugs (I hope that this is not one of them).
Real problem is that I can't localize this error and it may take me 3 day to find it because it is big VI!
Can somebody help me with this problem!
Thank you in advance,
Andrej
(4,319 Views)
Hi Andrej,
Are you using global variables with cluster data types by any chance?  We have a minor known issue with those on PDA that we've found a simple workaround for.  Of course, if you can isolate where the error is coming from that will make it much easier for us to help you.  If you can narrow down the code to something simple that shows the behavior, then post it here and we can take a look at it.
Cheers,
Matt Pollock
(4,309 Views)
I am having a similar problem.....
I get a measurements_fetch/destroy/  everytime I try to add the pulse measurements.vi to my pda application.  This token does take clusters, so that may be the bug you are discussing.  What is the work around you are refering to??
Corey
(3,780 Views)
