pda unflatten from xml
I want to know why I can't build an executable for PDA with the unflatten from xml.vi in my VI?
Laurent
(3,208 Views)
Hi, the PDA doesn't support the unflatten from xml.vi
http://zone.ni.com/reference/en-XX/help/372508B-01/lvpdagsm/pda_lvclass_support/
regards
(3,172 Views)
Ok, I know that, but Flatten to xml.vi work, Flatten to string and Unflatten from string work too.
Your list is too old because I use the last Labview version the 2010 sp1.
So Why I can't build an executable with Unflatten from xml so that I can do with Flatten to xml? I can do also with Flatten to string and Unflatten from string.
regards
Laurent
(3,169 Views)
Do you get an Error Message?
(3,160 Views)
I'm sorry, I didn't think that question was so difficult.
Yes, I get an Error Message.
Error Massage:
UnflattenFromXML is a missing VI or C file.
Details:
There was an error building the executable. Please check the VI's or C files that were added.
But I don't know why Labview says that  the VI is missing?
I've instaled all Labview software and all mobile module options.
regards,
Laurent
(3,157 Views)
Accepted by topic author lagrive
Thanks for sending the whole error message.
This is a known issue and our people from R&D are working to correct that.
This is being tracked by NI Corrective Action Request 277159.
Problem Details from CAR 277159:
Compilation fails for a Mobile Module VI that contains an Unflatten from XML function with the error in terminal wired.  When you compile this, it returns the error "UnflattenFromXML is a missing VI or C file.
(3,155 Views)
Ok, Thanks for your answer(s).
regards,
Laurent
(3,152 Views)
