pda
Hi there
I have a problem of detecting the DAQ Card CF-6004 in my PDA.
Under the Getting Started Guide, NI-DAQ mx Base 2.x, step 5: Confirm that your device is recognized
i do not see my  CF6004 listed under the *ai finite buffered*
can u help me ?
i have installed ni daqmx base 2.0 on the IPAQ hx2790b PDA.
I'm using Labview 8 with pda module activated.
Lance
(8,187 Views)
Hi Lance,
Does your iPAQ HX2790B run the Windows Mobile 5.0 operating system?  If so, you will need at least version 2.1 of the NI-DAQmx Base driver for support for this OS.  The most recent version that provides support for Windows Mobile 5.0 is version 2.2.  Let us know if this helps.
Andrew W
(8,165 Views)
yes, it is running on the Windows Mobile 5.0 operating system. i have fixed it using 2.0NI-DAQmx base driver already. Thank you
(8,137 Views)
