pda
hi all,
      i am very new to labview. i am having a black and white image and want to take the coordinates of the blak pixels in a array, i need help in how can i make array. i get the array of th epic from IMAQ colour image to array function then i am using two for loops and comparing the pixel value to 0. and if it is true i want to take the i values of the two for loop in a array. so i am un able to make array.
       thank you  in advance
cheers
harjeet
(8,552 Views)
Hi there,
Hopefully you will be able to try this.
It's very simple but should be scalable to a larger image.
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(8,487 Views)
thanks for your help adam
thats is appreciated
(8,117 Views)
