peak detect
Hello!
I´ve been using Peak Detect vi (version 7.1) to calculate ECG Peaks. I noticed that it finds the first peaks allright, but the more the ECG curve advances, the more Peak Detect returns peaks distant from the real peaks. Could it be that i should change Peak Detect´s width(i started with 10), or should i use another vi?
Thanks in advance,
Luanna
Message 1 of 13
(5,569 Views)
Hi Luanna,
Have you seen the following white paper
 http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/55181a206a523fd186256abe00626ea9?OpenDocument
hope this helps.
Cheers,
--Russ
Message 2 of 13
(5,562 Views)
Hi!
Thank you for the document! I read it but i´m still confused... my "peak detect" is findind the right amplitudes,
but the Time Locations are shifted(TimeLocations[i] = t0 + dt*[Locations]). There is a catch: the vi, before it runs "peak detect"
enhances the ECG signal. I´ve tried to take that out, but if i do "peak detect" doenst find any peaks at all.
So, using the enhanced signal and "peak detection" i´ve tried to run my application inputing
less data (just 1/3) and still the locations are shifted, mainly at the end. I also changed width(less, more), but it didnt get any better... what could i be doing wrong?
Thanks for your help!
Luanna
Message 3 of 13
(5,532 Views)
I guess i am a little confused reading this - to help you I think we would need to see a screenshot of the program that is written. Are you cropping the data at all, using a multiplier, or otherwise doing something that would adversely affect the X-Axis. And are you sure that the t0 is set up to the right number, as in will it always be off by some random number, or is it a consistent number that it is off by each time?
Tom
Message 4 of 13
(5,514 Views)
Hi Luanna,
Is the vi you are referring to before your peak detector a filter of some type? If so this could be the source of the time delay.
look at
https://forums.ni.com/t5/LabVIEW/is-phase-shifting-a-side-effect-of-digital-filtering-the-higher/m-p...
or
https://forums.ni.com/t5/LabVIEW/Filtering-noise-from-a-sinewave-how-to-compute-introduced-time/m-p/...
or
https://forums.ni.com/t5/LabVIEW/Difference-between-filters/m-p/101798?query.id=23332#M62137
these are just some of threads that discuss the delay introduced by filters you could search and find even more I am sure
hope this helps
Cheers,
--Russ
Message 5 of 13
(5,507 Views)
Message 6 of 13
(5,503 Views)
Thank you, unclebump! I´ve looked the links, and i think that what i´m using is not exactly a filter. I say "i think" because
this vi is not mine, and i´m still trying to understand it... I´ve attached an image of what is done to the signal before it passes to
"peak detect". If you could look, please.
Thank you very much for your support.
Luanna
Message 8 of 13
(5,472 Views)
Luanna
The first problem that I see with your code is that you take a derivative. Math tells us that if we are taking a derivative of a function, lets use for example sin and cosine. If you take the derivative of sin(theta) you get cos(theta). I don't know exactly what the ECG function you are looking at looks like though, but I can assume that part of your problem stems from the derivative.  Also, the hilbert function is an envelope creating function and has been accurate for all wave envelopes I have taken for ultrasonic signals.  We do something different with our hilbert transform. That subvi is also included along with the sin/cos graph to show you the peak can change in time(or degrees in this instant).
Try overlaying the graph you are using to pull off the peak with the original ECG also, that may help.
Tom
Message 9 of 13
(5,457 Views)
Hello, Tom, i´ve checked your tip and you´re right, the enhanced signal has peaks different from the original signal. Thanks! Well, now i´m trapped 🙂 Do you have any peak detection code, specific for ECG?
Actually, peak detection is the first problem. The main problem is that, after peak detection, i calculate rr intervals and use the RR curve to calculate power spectrum(FFT). My power spectrum has many peaks, what is not how a RR interval spectrum should look like. I thought that could happen because of the shifted time locations, but i dont know if it has that much influence over the FFT.
In short, i´m quite lost... a more precise peak detection algorithm would be of great help.
Thanks for everything!!
Luanna
Message 10 of 13
(5,414 Views)
