peak detector not functioning properly
Hello I am not getting all my values from the peak detector. Can someone help me. I have probed the specific areas and tried changing numbers but that did not work. The file name is activation times and the tdms file name is test1. thank you
(3,681 Views)
You haven't supplied all of your VIs. "reg dirivative" is missing.
Usually it's more helpful if you simplify your VI to not include the File read/write operations and just read data from a constant. THis makes it much easier for us to work with your code.
Cheers
(3,668 Views)
Hello reggie2016
Could you please attach the missing VI? To see if we are able to figure it out why your code is not working properly
Joshua Barr
Applications Engineering
www.ni.com/support
(3,617 Views)
