peak/valley detection problem
How can i detect the maximum peak to valley on the graph attached.  It is not the difference between the maximum and minimum all the whole data set that i require, I want to know the maximum value of the higher frequency peaks and valleys ignoring the small 'blips' within the data.
The X-axis is controlled by time and the number of samples between each peak varies between data sets.  I have considered using a moving average to smooth the data but cannot do this due variation of samples between peaks.
Using the peak/valley detection VI would work great but due to the small 'blips' in the data set a true maximum value cannot be found.
Can anyone help?
Tom
Message 1 of 9
(6,206 Views)
Hi Tom
I'm not really sure which values you are after. Could you indicate which peaks/valleys you are interested in in the image you attached?
Best Regards
David
NISW
Message 2 of 9
(6,199 Views)
The value i want to know is the difference between each of the coloured lines, ignoring any 'blips' inbetween.
I then can easily find the max value.
Some of the blips have been circled.
Tom
Message 3 of 9
(6,183 Views)
so you want to find the maximum point on the graph?
because if thats the case you can do this...
Message Edited by Harold Timmis on 10-22-2009 11:05 AM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 4 of 9
(6,177 Views)
Do you have the raw data in a format that we can use? I have a program that I think will work for what you are trying.
Tim
GHSP
Message 5 of 9
(6,172 Views)
Please find data attached.  The VI contains a constant with data and a graph.
Message 6 of 9
(6,152 Views)
Hi Tom,
I have been looking into your issue in an attempt to find you a solution. My initial thoughts are that you should apply some form of smoothing to the waveform before subjecting it to the the Peak Detector sub VI to detect the amplitude of the peaks and the troughs. These amplitudes could then be subtracted form each other thereby arriving at the values you are looking for. Can I confirm that this would solve your problem.
I have been looking into a methodology for smoothing your waveform and I found the following example which uses a moving average technique, which I think could be useful. Take a look and let me know what you think.
Best Regards,
Christian Hartshorne
National Instruments UK
Message 7 of 9
(6,073 Views)
Could you please post the moving average VI in version 8.5?
Tom
Message 8 of 9
(6,061 Views)
H Tom,
Here is the Moving Average VI in LabVIEW version 8.5. Hope this helps.
Message 9 of 9
(6,058 Views)
