pen and view picture in labview
Hi
I want open and view picture in labview, like below.
How can I connected "Build Path" out put to "Picture" input?
Thanks.
(2,947 Views)
Do something like this
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,931 Views)
Hi Mayayi,
You cannot wire  file path into a picture indicator... Try use the quick drop menu (ctrl+Space bar) and type "Read JPEG" use that function to flatten a JPG image to a flattened Pixmap, then using the same method, get the draw flattened pixmap using the "draw flattened pixmap.vi"  and wire the result into the 2D picture indicator.
I would strongly recommend using the LV help and maybe Google before consulting the forums!
Regards
Andy
_______________________________________
"To 'G' and not to 'C', this is not a question!"
(2,926 Views)
Thanks AdnanZ.
But when I use below form, it doesn't work. "Read Jpeg file" has Error.
please help me.
(2,920 Views)
ok, sure.
thanks AG@Amfax  Smiley Happy
(2,917 Views)
Mayayi,
Check the file path you have generated is correct.
Regards
Andy
(2,913 Views)
Thank you soooooooo much Smiley Happy
(2,903 Views)
