performance and memory usage
I want to check the performance and memory usage of my vi.
i used Tools-->profile-->performance  and memory
I am getting zeros.I opened my vi then went to the Tools-->profile-->performance  and memory
i can see lot of vis are opened in the profile data. Is there any something wrong with the path.
(4,048 Views)
Did you press the help button to get more details on the tool? For example did you press "start" to start profiling.
What is the difference between the second and third line of your post?
Why do you think there is something wrong with the path? What path?
(4,040 Views)
I do see the same 0s.
See attachment.
Any help! Please!
Thanks, Andrey.
(3,988 Views)
You did not check the see timing statistics, so why should it return something related to timing?
Did you scroll right? Did you scroll down?
(3,982 Views)
- I am not interested in the timing that is why I didn't check. I suppose that in this case dialog shouldn't show Timing column or, as minimum, show 0s.
- I do scroll down. All are 0s.
- I made another test and ckeck Timings statistics and details. Result - all 0s.
I use LabVIEW Proffessional 2011.0.1f1 (32 bit( SP1
Thanks!
(3,979 Views)
You're aware that those values do not update until your click "Snapshot" or "Stop," right?  They do not update continuously.
(3,972 Views)
that is bad Smiley Sad
Snapshot works!
Thank you!!! Have a great weekend!
(3,967 Views)
