performance comparison---using LABVIEW..between Embedded and general-purpose Intel's single VS multi-core CPU
hi guys;
kindly, can any one tell me : is it possible to use Labview installed on desktop pc to show up statistically the main performance key features between mutlicore systems and single core systems but with (two versions, embedded and general purpose CPU) . in other words: I'm trying to resemble embedded cpu with general purpose CPU so that i can only work on Desktop pc than say that the obtained results are the same for embedded multicore CPU.
to get things more clear:...embedded multicore processors are now hitting the embedded market segments such as (small and portable devices with internet, multimedia and wimax tech. enabled that take advantage of recent multicore tech.).
general-puroses Multicore processors: like desktop and servers based processors,
according to what 've read, Intel is producing same processor model but with different applications : (embedded and general-purposes applications)
(3,388 Views)
Please look at this page which shows a new feature in LabVIEW 2009, but particularly interesting is the video which shows the performance benefits on a PC platform of single core VS multicore.
LabVIEW doesn't have any ability to emulate a multi-core embedded processor (unless its an intel x86 processor that labVIEW supports!) so to discover the performance benefits of embedded multicore processors, you would need an external hardware board and devise a test in which labVIEW can measure the timing via an external pin toggled by a program running on the embedded processor that could utilise multiple cores (there may be other ways but this is the way that comes to my mind).
I hope this helps you!
(3,338 Views)
