period of 1d array
I need to measure the period of a 1D array of doubles. This data is taken from an encoder that puts out a square waveform. The problem is that the period changes every 1 cycle and I need to be able to accurately measure the period of each cycle. What function can I use to get this data?
Thanks!
Tim
(3,289 Views)
Do you have a small data sample you can post?  Regards, -SS
(3,275 Views)
I can think of 2 ways off the top of my head:
  • Use the Pulse Measurement VI to return to you the pulse widths.
  • Use the Transition Measurements VI to basically get the same thing.
(3,274 Views)
The problem is that the data acquired is not a waveform but a 1d array. I have attached some sample data.
(3,227 Views)
A 1D array can be turned into a waveform:
What is the second column in your data?
Message Edited by smercurio_fc on 06-23-2008 10:47 AM
(3,219 Views)
Sorry about that, the second column is another set of data from another sensor. I will give this a try and see what results I get. Will post any other problems here.
(3,206 Views)
