periodic reading data with event driven programming
Hi all
I want to read data from a device periodically, for example every 2 seconds.
but I want to use event driven programming in order to response user events.
now I don't know how to do this......!!
maybe I should use timed loop or timed sequence structure
if I use this structures, should I use then inside the while loop or outside the while loop( I mean the while loop that contains the event cases)?
please help me and accept my thanks....
(3,326 Views)
You ned to run these in two separate loops. Look at the Producer/Consumer template. Put a two second time-out on the Dequeue Element and you have a loop that will run every two seconds. The loop should also handle information from the event structure.
Separate loops is the best way of handling this.
Rob
(3,325 Views)
