perspective dot minimum required
using the perspective correction method via visual assistant, how many dots are required to generate a map?
i have tried using four and if refuses to use that few.
does anyone know the minimum required?
John P.
(3,084 Views)
after a bit of playing about i have found that 9 is a magic number, i have no idea if less works,
but i can confirm that 4 doesn't.
(3,082 Views)
Hi John,
could you elaborate on your problem please? Are you referring to the Vision Assistant? Would it be possible to attach the code that produces unexpected results?
KostasB
NI UK
(3,047 Views)
