perte de palette daq assistants
Bonjour,
dans labview 2011.
dans les palettes de fonction EXPRESS, Input, je ne retrouve plus l'icone daq assitant (pour creer des VI d'acquisition en express ).
Comment la récupérer.
D'avance merci
(7,120 Views)
Hi constantin,
is DAQmx installed?
(You know this is an English speaking forum?)
(7,118 Views)
hi,
yes DAQmx is intalled.
best regard
(7,111 Views)
Please provide some useful details such as the version of DAQmx and the order that you installed LabVIEW and DAQmx. DAQmx must be installed after LabVIEW.
(7,103 Views)
Accepted by topic author constantin
Please install DAQmx after the Labview installation and with activated support for the Labview version.
And see DAQmx and LabVIEW Version Compatibility
(7,099 Views)
install labview 2011.
then installs DAQmx DAQmx 15.0
I just saw that it was not compatible with labview 2011.
By cons on my laptop (same config but DAQmx 9.5) and it works.
I'll daqmax 15.0 uninstalled and installed a version for old route if it works
Thank you very much.
(7,086 Views)
I just tried with a good version of nidaq. it works.
Thanks again
(7,039 Views)
