pfeiffer tpg 261
Hi
I'm looking to create a pressure sensor similar to the double gauge sensor offered by Pfeiffer here: http://www.pfeiffer-vacuum.com/en/downloads/container
However, I would rather like to set the system up with the Pfeiffer SingleGauge, a single-channel measurement and control unit for compact gauges: http://www.astro.ufl.edu/CanariCam/components/singlegauge.pdf
Any ideas on how to begin? Thanks
(5,658 Views)
Hi inneedofhelp,
This probably isn't the best forum for finding information about creating sensors since we don't make those products. I wish you luck in your project.
Steven K.
Software Engineer
(5,623 Views)
I believe this is the same question as what he asked a couple of days ago: http://forums.ni.com/t5/LabVIEW/no-sensor-detected-possible-serial-communication-issue/m-p/1404798
(5,616 Views)
