pfi
where can I get a comprehensive manual about pfi , routing, ... ? I've read the forums and the NI 9178 manual, but I really don't understand anything about it.
I'm trying to read a quadrature encoder (A,B and Z signal, 4096 pulses) , apparently I need a second C module to generate a clock or timebase?
I don't understand why, but ok. Enclosed my example, I have a NI 9178 chassis, Module 5 is a 9411 module to read the encoder and module 6 is
a 9401 module to generate a clock. The example doesn't work however? I tried a lot of things, always getting errors like:
Sample Clock Rate must match the frequency of the internal timebase specified as the Sample Clock Source,
Specified route cannot be satisfied, because the hardware does not support it,
I/O type of the physical channel does not match the I/O type required for the virtual channel you are creating,
I just want to read the encoder at a fixed sample rate , eg 10 kHz and 10000 samples
Is there a simple explanation of routing, how it's done, what's the meaning of all the different timebases, how the interprete the routing table ...
What's the difference between CO pulse freq > counter output > pulse generation > frequency, time, ticks ?
What's two edge seperation, semi-period, ...?
Thanks in advance,
Ronny
(3,861 Views)
anybody who can help me?
I want to read a differential encoder, so I guess I need the NI 9411.
I don't understand how to generate the external clock. Do I use the NI 9401 for that or better the chassis counters? What's the difference?
I tried it with DAQ assistent, but doesn't work. Now tried it with signalexpress: first step is DAQmx generate: counter pulse output on ctr0 of NI9401,
which suggests output on PFI5.
Next step is DAQmx Axcquire: Counter Angular Position, there I choose external clock: clock source /cdaq1Mod1/PFI5,
but then I get an error "Specified route cannot be satisfied, because it requires resources that are currently in use by another route." ?
thanks again,
Ronny
(3,809 Views)
Anyone can help me?
(3,776 Views)
(3,702 Views)
