07-02-2013 02:29 PM
Hi guys,
I need a single phase inverter, do anyone know how it called in labview i can't find it anywhere :P..??
Otherwise to create an one...I need some help
Thank's a lot..!!!
07-02-2013 03:16 PM
How about inverting the signal (multiply with -1)?
07-02-2013 03:36 PM
That's a good idea..But henrik,
I thing if I do this (maybe I am very wrong) the singal will be a singal in binary system (throb)..
or not..?
07-02-2013 03:42 PM
Please tell us what kind of signal you have. The term "inverter" is used in many different fields with quite different implementations.
What generates the signal? What should the output be for various settings of the parameters of the input? Is this all software or is some kind of measurement or control hardware involved? How much data will be present each time the inverter is called? How often will it be called? How fast must it work? Are there specifications on accuracy or noise or other parameters?
Lynn
07-02-2013
06:54 PM
- last edited on
05-06-2026
08:18 AM
by
Content Cleaner
nionios27 wrote:I thing if I do this (maybe I am very wrong) the singal will be a singal in binary system (throb)..
You need to be more specific. What is a "binary system"? This term is way to generic to be useful. To invert a boolean use NOT.
Earlier you talked about inverting a phase. Is your signal complex?
